1982 RSC Honda RS200T Competition Trials
The Hell Team
Dealer
Dealer
Contact:
Postby The Hell Team » Fri Aug 09, 2019 11:08 am
A very special Honda RSC RS200T Trials bike.
One for the pool room, or Twinshock competition, whatever your fancy.
DETAILS
In 1970 Honda created a separate company for the development of special racing motorcycles and parts. This company was called RSC, Racing Service Center Corporation, later in 1982 the company was renamed as HRC, Honda Racing Corporation. The best Honda Trials bikes were designed and developed by RSC or HRC, they were limited numbers, competition bikes only. Not to be confused with the production TL's or TLR's these were hand made and to a very high specification in the day.
Today they are highly sort after by trial aficionados and Honda enthusiasts worldwide.
1979-82 Honda RS200T (Honda Code NA3)
The RS200T was built from RSC, Racing Service Corporation mounting a Honda, air cooled, four stroke, single cylinder engine inclined at 15º with 197,74cc displacement.
The RS200T had the frame number following the TL200RII, and began with the 2510.
All these machines were engraved with the name RS200T – XXXX (x means the number)
The RS200T had alloy red painted fuel tank and fiber support seat with oval windows on sides.
The swing arm were on these units light alloy made, had other details as the perforated rear aluminum axes.
Replacing the TL200R small front forks the RS200T was 33mm diameter Showa forks.
First RS200T bikes had plastic engine plate protector.
All these bikes were produced in a really small series.
There is several informations saying that around 400 units were made.
The ENGINE
Gasoline air cooled 4-stroke
Displacement 197,74cc
Valve train: Overhead camshaft chain drive
Maximum Horsepower: 12.1 at 6.000rpm
Maximum Torque: 1.59 at 4.000rpm
Compression ratio: 8.2
Ignition, CDI
The TRANSMISSION
6- Speed transmission constant mesh
Clutch: Wet multi-plate type
The FRAME
Diamond Type, aluminum swing arm
Front suspension 33mm, 70mm travel
Rear suspension aluminium swing arm 40mm travel
Fuel capacity 3 lit
Caster angle 26º
The DIMENSIONS
Weight 85.8Kg
Wheel base 1314mm
Seat height 720mm
$6100.00
We can crate and freight bikes Australia wide (and internationally). Please contact us with your location for an accurate freight quote.
The Hell Team Trials Store
02.8424.6400
0418.415.129
whoever@thehellteam.com
http://www.thehellteam.com
Return to “Dealer classifieds”
