14 mm decompressor Valve
rudge250
Bike: Montesa
Postby rudge250 » Tue Dec 05, 2017 4:38 pm
try as I may I cannot find any information on adapting a 14 mm Valve to the threaded spare hole in the Cylinder head of my 247 T Cota. The Head thread hole is approximately 11 mm and probably Metric. Will it safely tap out to 14 MM ?
Or is an adaptor available somewhere ?. Thanks Sean
:D :NSW:
P.S After many hours the Electrics are now working, were a total mess !!! Speedo opened and repaired, waiting for a Cable from the UK. Chain Guard on order fro Germany ,, metal.
rudge250
Bike: Montesa
Re: 14 mm decompressor Valve
Postby rudge250 » Wed Dec 06, 2017 4:04 pm
:NSW: :D Hole taped out to 14 mm ok. made a tap from an old Spark Plug. Apparently the thread pitch is not std. and peculiar to 14 mm plugs ,so says internet search ?
OlDaz
Bike: Cota 247
Postby OlDaz » Wed Jan 24, 2018 3:20 pm
"Standard" M14 as used for bolts has 1.5mm pitch, spark plug is M14 x 1.25 which is a standard metric fine thread.
If you have a stripped spark plug hole, the repair kit uses a 1.25mm pitch tap that uses the original threads as a guide, then you wind in the stainless insert to get you back to M14 x 1.25 thread.
The second hole on my 247 was stripped sometime in the past and plugged with a custom M12 "plug" to seal it - I'm considering repairing this thread to fit a decompressor with M14 x 1.25 (spark plug thread) while I have the engine apart.
Still remembering when.....
Users browsing this forum: Google [Bot] and 9 guests
