250 Majesty finally ready to ride
It's taken a few months to complete but the Majesty is finally ready to ride.
I'm very familiar with riding TY250 twinshocks and seeing that so many TY250 parts are reused on the Majesty I'll compare them.
The main difference is the rear suspension action. The Majesty takes far less effort to get the bike over obstacles due to the rear suspension travel increase and reduced damping effect (same shockies-more leverage-stiffer springs). The other benefit is better traction on uphill rolling rocks and going over slippery things.
Next to notice is the ergonomics. There is lots of room to move around. I suspect the handlebars are higher relative to the footpegs and may also be a bit further forward relative to the footpegs.
There is more ground clearance under the engine which I notice most riding over obstacles going downhill.
The Majesty is not lighter but does feel lighter to ride due to the improved mass centralisation so it is easier to flick around in the air and takes less effort to ride.
It is a bit easier to balance on due to the low footpegs.
All the other virtues of the TY250 are still there which make both the TY250 and Majesty great to ride ie the motor performance, clutch, brakes and ease of kickstarting.
I'm also familiar with the Cota 348 and reckon the Majesty feels like a 348 would feel if fitted with a TY250 motor and lowered footpegs.
The motor is a TY250D with the only engine modifications being the removal of the steel band from the flywheel and rejetting of the carby. I don't see any need to big-bore the motor or change the compression, porting etc as it goes like a dream already.
Majesty
Nice Majesty David
What gearing you using on the final drive?
I ride a Mk2 godden Majesty 250 and run 10, 42 gearing.
I am looking to go up 2 teeth on the rear to make use of more gears,like over here we get some serious mud climb sections, so i need a taller gear for these conditions,plus the fact i dont want the expence of building a 320 motor, being a tight fisted pom!
Cheers Andy
Cheers Andy
- restoremaz
Users browsing this forum: No registered users and 39 guests
