Oil injector
AzzA
Oil injector
Postby AzzA » Sat Dec 13, 2003 7:16 pm
Hry guys,
Is it O.K to remove the oil injector off my 2 stroke??
As long as i premix the fuel, it should be O.K right??
cheers
AzzA
premix on injested bike
Postby David Lahey » Sat Dec 13, 2003 10:37 pm
Dear Azza
Most 2 strokes can be run on premix after removing the pump and hoses and blocking the injection point. However some 2 strokes dose oil to other places as well as the usual (inlet tract) so internal mods would be needed to the engine in that case.
Generally if there is only one dosing point and it is into the inlet tract it is a simple job to convert to premix. Beware that the fuel air mixture ratio will be affected a bit due to the physical properties of the premix (being metered by jets) being different to straight petrol.
Return to “Technical help”
