fork oil for 1998 beta techno 250
can anyone help with fork oil weight ,amount and sugest a good brand for my 1998 beta techno 250. rider weight is 95kg. pete mck
Re: fork oil for 1998 beta techno 250
Gday Pete, 360 cc in each leg is the amount, there is no recommended weight, 5 is usual, I use ATF Dexron 3 which is about 7.5 weight and heaps cheaper. Any brand is OK. While you are there it is probably more important to check the spring, I know mine has sagged a bit as the bike (99 Techno) has about 30 mm of static sag with the preload set fully in ( I weigh about the same as yourself). It should have about 10 mm on a trilas bike. Basic suspension rule that most people get wrong = Fork oil does the damping, the spring holds the bike off the ground!
HTH,
Stork
HTH,
Stork
Users browsing this forum: Google [Bot] and 15 guests
