89 Honda RTL 250S
sharvie
89 Honda RTL 250S
Postby sharvie » Tue Mar 08, 2011 6:49 pm
Looking for a specs sheet on the 1989 Honda RTL 250S
E.g. Dimentions
Frame
Engine : Maximum power, Maximun torque
Carburetor
Drive train
Looking to make comparisions with the TLR 250
Regards
Steve
Sharvie ~ Maitland NSW
brownie
TA Supporter
TA Supporter
Bike: Bultaco's
Club: denman
Re: 89 Honda RTL 250S
Postby brownie » Wed Mar 09, 2011 7:33 am
sharvie
Postby sharvie » Wed Mar 09, 2011 10:10 am
Thanks for your reply Ross,
I had seen that web site, but not that page. There are no specs particular to the 89 model.
Apparently there were small increases in HP each year from 85-89.
Realy after the specs sheet as would have been in workshop manual for the 89 model
Regards
Steve
FM350
Bike: Fantic
Club: Otter Vale
Postby FM350 » Fri Apr 15, 2011 2:27 am
Other than the obvious differences such as the mag side cases, and different kickstart mechanism the RTL motors are pretty much identical to the TLR 250. However later ones as fitted to disc brake bikes have different crankcases, and a slightly bigger clutch. The later motors can be easily recognised by the fact that the oil filler is on the front of the primary case rather than toward the rear on the earlier bikes.
Main reasons the RTL's seem to run so much better than the TLR has to do with the HRC exhaust system, and an ignition system that seems to provide a more trials specific advance curve. Generally TLR's are fitted with very restrictive exhausts and retain the stock air filter which also isnt ideal for competition use.
Return to “Technical help”
